What a great idea this thread is. I applaud you John and look forward to more gems. Did you ever use the Talbot factory method of setting valve clearances?
Doddsworth Tips
Core Plugs
Hi chaps, as far as I know all core plugs in Talbot
Engines are screwed in, usually 1.5 mm pitch. Doddy....I had a detailed tutorial on this from
14/45 Cylinder block oil gallery pipe plug removal
Can anyone please advise if the aluminium plug in the rear of the cylinder block oil gallery tube is threaded, and if so what is the thread?
I...
Doddsworth Tips
What a great idea this thread is. I applaud you John and look forward to more gems. Did you ever use the Talbot factory method of setting valve clea...
Distributor points setting (Doddsworth and Ian Potts)
Hi all, in the 1970 & 80s the Vauxhalls with Delco Distributors ( you know the ones with our points ) used to nearly all have a worn out Distributors....
Scale trap for cooling system
Hi Martin L, it just realised with your new Talbot 14 weather you had run it yet if you have then it's too late. But I have a Dodd sewer that you can...
