I thought I would submit a post to say 'hello' to you all.
Introduction
Hi I am in need of some information to complete the engine rebuild on my 1934 Talbot AV95 Light Six Wide Bodied Saloon.
Can the cylinder head valve seats be machined out and replaced with new hard valve seats?
Are there any machining issues such as break through into water galleries are stepped seats required?
I have a long way to go with this car but I am on a roll at the minute and the engine is re white metalled re bored cam sorted followers re faced and I just need to fit the sump.
Does anyone have a photo of the oil pump pick up filter and the Hobson Telegraph that goes into the sump?
The car came to me having had its sump and radiator stolen for scrap, John Dodd sourced a sump for me and a radiator which was from a 75.
I swapped my 75 radiator for a radiator and complete surround for a 95.
I also need a Pre Selector gearbox as mine has been stripped and scattered to the four corners.
I intend to re build the car as a four door saloon as these are quite rare now as most have been chopped to make other model copies.
Any help would be much appreciated as I want to get her on the road.
This car was a Stockport car and belonged to the Robinson Brewery family and was sold by David Rosenthal from the original Manchester airport.7n7
The car was taken off the road in 1953 with smoking and gearbox issues and I rescued it in 2015.
I would like to keep the original number but only have old tax discs from51,52, and 53 but DVLA no longer take these as proof of registration. Does anyone remember this car or have period photos?
Any help would be much appreciated.
75 Assistance
I have tried unsuccessfully since the end of last year to get my 75 running again. I am unable to get fuel to the carb, having replaced the fuel filter...
Dynostart wiring
Hello Talboteers,
Enquiring if any of you experienced gearheads could offer some guidance? I'm up in Ayrshire Scotland replacing wiring on two separate...
SU Electric Fuel Pumps
I have finally decided to give up on my quest to get the the mechanical AC fuel pump to work on my car and have decided to fit an SU electric pump. Can...
