Fuse box cover
  • Fuse box cover
    Greetings all. I'm looking for the top cover for the 105 fusebox, the larger of the two enclosures, down at the bottom of the n/s bulkhead. I've emailed the TOC spares to ask about theirs but can anyone else help? Not looking for a pristine example, just serviceable. Thanks in advance.
    Good morning Geoff.
    I'd give Alex Leach a ring on ‭07931 679935‬. He will probably know what you need and if he or Polson have one. You could also try Foppe D'Hane at dvp.restorations@hotmail.com
    Good luck in your search.
    Doug.
      I made one for a car once, it wasn't too difficult. Mine was aluminum but 1-1.2mm steel would work too. Just fold the edges and drill a whole in the center, paint it and away you go.
        I made mine (the lower one in this picture) from 5mm rigid plastic board, superglued to form the shape. Not very original but does the job and looks okay-ish.
