Timing Gears
  • Timing Gears
    What back lash should there be between the crank and camshaft gears?
    Dick,
    I see that the STD forum has come up trumps again with Jim"s answer! I am trying to find an answer for the 14/45 as I suspect that it would be similar to the 105 but no luck so far.
      I was in touch with Martin Lawrie and he has a new timing gear he has fitted and reports that the backlash is .008" - within the range quoted by Jim.
        I agree....0.008" it will be.
          ....and I can now report that the 0.008" provides silent running with the steel gears provided by Foppe de Hane.
            If it helps, below are the notes I made when trying to work out the backlash between the crank timing gear and fabroil cam gear. Tests were done with Vinnie Rawlings: -
            Backlash – camshaft gear on test rig (18HP)
            Measured at gear o/o
            Unused Roots Fabroil gear 0.020”
            Doug Reid's OE Fabroil gear – 68k miles 0.040”
            New Fabroil gear (Foppe D'Hane) 0.047”
            New Fabroil gear (Vincent Rawlings) 0.024”
            __________________________________________________ ____________
            Test rivet length 1.030”
            Hub assembly thickness 0.910”
            Rivet protrusion 0.120”
            Basic rivet length 1.030”
            + 0.030 parallel at 3/8” diameter 0.030”
            1.060”
            Drilled letter B 0.238”
            Rivet diameter 0.238”
