On my way to the Kop Hill Climb event on 21st September 2019, the engine on my 14/45 Scout seized going up the hill on the A404 half a mile from the M40. I had just changed down to 3rd gear as it was struggling in top and shortly after the engine faded. The engine had seized, I suspect due to overheating.
I have removed the cylinder head, dynostart, sump, pistons & con-rods and apart from some slight scuffing on the pistons it all looks ok. However, it is quite hard to turn the crankshaft for about one and a half turns, but frees up for about 180 degrees of crankshaft rotation, which tends to indicate something to do with the camshaft. I have removed the fuel lift pump but it makes no difference and the oil pump and distributor gears are free and offer no resistance.
The cause was blocked water manifold ports opposite cylinders 1 and 6 (see attached photo), which caused overheating. As a result the front camshaft bearing seized, resulting in the camshaft journal picking up material from the crankcase bore (see attached photos). To remove the camshaft I had to grind the high spots on the front journal with a fine grinding wheel in an electric drill after finding the high spots with engineers blue. This was not ideal but I tried using carborundum sticks, which was not working and taking far too long. As it was I spent 13 hours doing this.
I now have a problem as to how to rectify the resulting damage. I am not aware of any camshafts with oversized bearing journals. Can anyone offer any recommendations please?
